In modern cloud architectures, enabling secure and controlled outbound internet access for private resources is a common requirement. Two widely used solutions offered by cloud providers to achieve this are NAT Gateways and NAT Instances. Both serve the core function of Network Address Translation (NAT), allowing resources within private subnets to initiate outbound connections to the internet while remaining unreachable from the outside, but differ in terms of scalability, automation, cost-efficiency, and operational overhead. Choosing the right approach depends on your specific networking needs, security requirements, and budget constraints.
cloud-nat-diagram
NAT Gateway
A NAT Gateway is a fully-managed, scalable, and high-availability service provided by cloud vendors. It allows outbound internet traffic from private instances while preventing unsolicited inbound connections. NAT Gateways are typically deployed in public subnets and are linked to route tables that govern private subnet traffic.
second-diagram-nat
Use Case
Ideal for enterprises seeking zero operational overhead, high performance, and automated scaling for NAT traffic, especially in production environments.
Advantages of NAT Gateway
Advantages of NAT Instance
Fully managed icon
Fully managed
No need to configure or maintain OS-level settings
Scalability icon
Scalability
Automatically scales with traffic volume
High Availability icon
High Availability
High availability by design (per availability zone)
Cloud Integration icon
Cloud Integration
Integrated with cloud-native monitoring and billing tools
NAT Gateway and NAT Instance – Enabling Secure Outbound Connectivity in the Cloud
NAT Gateway PDF
NAT Gateway
A NAT Instance is a virtual machine configured to perform NAT functions manually. Unlike a NAT Gateway, this approach requires the user to configure and manage routing, firewall rules, and OS-level NAT features. NAT Instances offer greater flexibility and control.
cloud-nat-diagram
Use Case
Best suited for environments that require custom traffic policies, deep packet inspection, logging, or cost optimization for medium to large-scale traffic.
Full Control icon
Full Control
Full control over the OS and network stack
Customizable icon
Customizable
Ability to run custom software (e.g., DPI, monitoring agents)
Cost Effective icon
Cost Effective
Can be more cost-effective in high-traffic scenarios
Flexibility icon
Flexibility
Flexibility in choosing instance type, size, and features
Advantages of Using VyOS as a NAT Instance
VyOS is an open-source network OS that provides advanced routing, firewall, and NAT functionality. When used as a NAT instance in cloud environments, VyOS offers several benefits over generic Linux-based NAT setups:
Check
Enterprise-grade features
Advanced NAT, firewall, QoS, and VPN capabilities in a unified platform
Check
Customizable and lightweight
Tailored images for cloud providers with minimal overhead
Check
Consistent experience
The same CLI and behavior across cloud and on-prem environments simplifies hybrid deployments
Check
Configuration as code
All configuration is text-based and fully automatable (via CLI or API), ideal for infrastructure-as-code pipelines
Check
Persistent configuration
Unlike some traditional VMs, VyOS ensures config survives reboots and is easy to version-control
Check
Strong community and support options
Commercial support is available, and the open-source community is active
Guide icon
Download AWS NAT Gateway and NAT Instance - Whitepaper
Download
Guide icon
Download Azure NAT Gateway and NAT Instance - Whitepaper
Download
